02 Dak QC Diff oil change
Old May 9, 2008 | 12:55 PM
wildcat27's Avatar
wildcat27
Default 02 Dak QC Diff oil change
I need to change the differential oil on both front and rear pumpkins on my dakota. I glanced underneath the truck and did not see a drain plug. Do I have to remove the pumpkin cover to drain the oil? Also what weight oil should I use. Thanks for the help!
Old May 9, 2008 | 04:10 PM
noodle's Avatar
noodle
Default RE: 02 Dak QC Diff oil change
Yes you have to remove the cover to drain the gear lube out.
I like to use thicker weight lube, i always use 85-140. May just be me but i like it thick.
Old May 9, 2008 | 05:16 PM
KodiakJeff's Avatar
KodiakJeff
The service manual calls for 75W-90 in the front and 75W-140 in the rear.
In my opinion, synthetic is the way to go. Try AmsOil, if you haven't already.
Good luck,
-Jeff
Old May 9, 2008 | 05:41 PM
dualdakota01's Avatar
dualdakota01
don't forget the good old friction modifier additive from cryslerfor the rear end. really helps with any noise from the posi rear end. if u have one.
Old May 10, 2008 | 09:36 AM
wildcat27's Avatar
wildcat27
Thanks for the input guys that was what I was looking for!
