Connect gauge air/ratio
Old May 12, 2008 | 01:11 AM
nascar.one@skynet.be's Avatar
Default Connect gauge air/ratio
I need to help, i connect on O2 sensor up or downstream ?
thanks,
the little belgian
Old May 12, 2008 | 02:28 AM
varsis's Avatar
varsis
Default RE: Connect gauge air/ratio
I would do the up stream.
Old May 12, 2008 | 08:34 AM
Thanks,i'm going to try
Old May 12, 2008 | 09:12 AM
middleriggle's Avatar
middleriggle
I agree with varsis, if you do it downstream, the data will be skewed because the cat with process some of that waste. If you want a true reading, gotta do upstream.
Old May 12, 2008 | 10:59 PM
00DakR/T's Avatar
00DakR/T
Understand also that if you install a narrowband air/fuel gauge to almost any fuel-injected engine, the readings on the gauge will be meaningless. The computer adjusts the air/fuel ratio so fast during engine operation that the gauge will do little more than bounce back and forth. For accurate readings, you have to have a wideband when you are talkin about EFI
