Dakota With Natural Gas Conversion.
Old May 20, 2008 | 07:11 PM
fivehundo's Avatar
fivehundo
Default Dakota With Natural Gas Conversion.
Has anyone out there converted a Dak to run on compressed natural gas? I've heard that the conversion is pretty easy and you can install a switch to have the car run on either gasoline or natural gas.
Gas prices are ridiculous out here and CNG is a rough equivalent to around $2.50/gallon, so I think it's time to look into other options. I've been told that kits range from $1500 to almost $2000, which should pay for itself in a month or two, these days.
If anyone has more information on this, I'd be really interested to hear about it!
Old May 20, 2008 | 08:11 PM
batman13's Avatar
batman13
Default RE: Dakota With Natural Gas Conversion.
well with the prices of natural gas about ready to spike....
i'll stick to gasoline
Old May 20, 2008 | 09:28 PM
RoaminGnome's Avatar
RoaminGnome
Ya with oil prices rising that pretty much screws everything. Most things regardless of what it is use oil in some form. Either for tranportation of in the manufacturing. It sucks but everything will go up at some point its just a matter of when and how much [:'(]
Mind you i wouldnt mind learning about doing a propane converion for an off-roader. no stalls during extrame angles is a good thing
Old May 20, 2008 | 10:39 PM
w9awx's Avatar
w9awx
I know we converted some of our deisel Ford vans to propane. Wasn't to terribly hard to do, from what the techs had said. But, this is not a overnight project either. It took our techs several days to do the conversion. Not sure how much easier or harder it is to do a gas to propane or natural gas conversion.
Old May 21, 2008 | 12:23 AM
fivehundo's Avatar
fivehundo
Even if Natural Gas prices go up,I could at least choose which fuel to use based on whichever is cheaper at the time.
Plus, it's a lot cleaner burning and if used exclusively, the engine will last quite a bit longer. Also, if I spring for the home refueling system, I can refill from home...
Old May 21, 2008 | 09:00 PM
artking's Avatar
artking
Propane (and I expect CNG also) has only about 75% of the power that gasolene has. You probably wouldn't save that much, and you would really miss the performance.
Art
Old May 21, 2008 | 09:38 PM
RoaminGnome
Tho if you wanted the eco option it wouldnt be a bad idea. Tho i think a cummins running on bio diesel would be better performance and milage. Just my $.02, and i would LOVE a cummins in my kota
Old May 21, 2008 | 11:29 PM
fivehundo's Avatar
fivehundo
ORIGINAL: RoaminGnome
Yeah, but biodieselis even harder to come by than CNG...
Does anyone know of a kit that's available?
Old May 22, 2008 | 12:06 PM
chris1974's Avatar
chris1974
with the gas prices being the way they are, im converting my truck to run on bullsh*t....becuase there is plenty of that to go around! lol
Old May 22, 2008 | 06:23 PM
fivehundo's Avatar
fivehundo
ORIGINAL: chris1974
...so, does anyone know who makes a conversion kit for a Dakota?
I'm pretty seriousabout wanting to do this...
