lights are acting up???
ok so I just replaced my front fender and doing so I had to undplug the lights and the Wwasher fluid ok...
so once I got done I plugged everything back in and turned onm my truck and the right turning single stays one and pblinks really fast when I use it not to menchon when my light are one in general my wipers kick in ... WTF my truck is goin mad what do you guys think could be the problem and how could I fix it??? thanks for the feed
kinda the same thing happen to me...i replaced alll my bulds (headlights, turns, side, tails, and fogs)
my blinkers flash 90 billion times a second
my low beams only work when my steering wheel is up
my high beams work reguardless of stearing wheel location
and when i replaced the flashers with used ones off a low millage one they still blink fast....
i posted about this eairlyer but no1 gave me any real imput so ur not alot i guess
Well, I know you have both a 1999 and an automatic transmission, but I would still give a look at THIS recall. (I don't know how differant wiring between 1999 and 2001 is).
I know there was a TSB (maybe even a recall) about crappy Central Timer Modiules (CTMs), but I can't seem to locate it right now. The CTM basically contols the headlights, wipers and the horn (amoung other things).
They can't seem to keep anything simply these days...
YEA 440... it was a ground that was lose it was bugging me the whole day so I tooke back off my light and checked the wiring and sure thing the ground wire was not connecting... just lil tightening fixxed the problem YAY! thanks for every ones in put!
no i still haveto deal with the problem bc any dealership i bring it to here just tells me its a wireing issue and bc i replaced them all(bulbs) its all on me and my warrent is long past gone... soo im just gonna wait till i got to college or get a bike to really look into it andtotaly rebuild my entire truck
