ABS/Brake light on and Speedometer don't work
Old Jun 23, 2008 | 10:43 AM
smokehouse's Avatar
smokehouse
Default ABS/Brake light on and Speedometer don't work
As stated in the title my ABS and Brake light are on and my speedometer does not work?
I own a '99 Dodge Dakota 5.2 Liter 4wd.
Thanks for any help
Old Jun 23, 2008 | 12:05 PM
yellowjacket99's Avatar
yellowjacket99
Default RE: ABS/Brake light on and Speedometer don't work
rear wheel speed sensor
Old Jun 24, 2008 | 12:08 PM
hellraiser775's Avatar
hellraiser775
Its the speed/ABS sensor mounted on top of the rear diff. I had the same problem with my 04.
Old Mar 16, 2009 | 04:49 PM
z250rider's Avatar
z250rider
is this an easy fix mine is doing the same thing
Old Mar 17, 2009 | 12:24 PM
yellowjacket99
Yes it's fairly easy and straight forward. Unplug the electrical connector, seems like there was one or two bolts to remove, can't remember if the sensor itself is threaded. If so un-screw it. Reverse that to install the new one.
