Manual transmission 2001 Dakota sport quad
Old Jan 23, 2005 | 10:19 PM
barnesjohn's Avatar
barnesjohn
Default Manual transmission 2001 Dakota sport quad
Have a 2001 with about 115,000 miles. For about 2 weeks the transmission would grind and rattle when I engaged 4 wheel drive.
Yesterday when I engaged 4 wheel there was a large clunk, and now switching to 4 hi or 4 low has no effect. The front wheels don't engage and there is no noise.
Any ideas about what happened or what repair costs I can expect?
Thanks!
Old Feb 2, 2005 | 11:54 AM
02dakota's Avatar
02dakota
Default RE: Manual transmission 2001 Dakota sport quad
Sounds like a problem in the transfer case itself. Putting your truck into 4wd should not have a huge effect on the trans except for maybe some bearing whine, or planetary noise. My guess is that something in the t-case bound and broke. There is a monsterous chain in there that I've seen break. Basically the chain connects the input shaft of the t-case (which is driven by the output shaft of the trans) to the ouput shaft of the t-case. Since there is no movement, it's possible that the chain went. They are usually very loud (rattling/grinding/clunk) when they go. Or you could've broken some gears or a shift fork. It sounds internal to me. Good luck...
