front end
Old Jul 20, 2008 | 09:11 PM
fireguy_64's Avatar
fireguy_64
Default front end
Ok here is my problem. I have a 2003 Dakota Quad Cab 2 WD. I have a loud poping sound or a loud thump sound in the front end.I also have a problem when i hit my brakes my truck goes to the left real hard and pops. The poping also takes place when you hit holes. It only mades the sound when you turn left. I put new brake pads on it Lastnight cause they were toast. My truck has 72,000 miles on it. Can anyone help me out??
Old Jul 20, 2008 | 09:23 PM
pumpkinheaver's Avatar
pumpkinheaver
Default RE: front end
Get it up on jackstands and inspect the front end, balljoints etc... Something isn't right!!
Old Jul 21, 2008 | 10:56 AM
fireguy_64's Avatar
fireguy_64
Ok after a new set of front brake pads and a new ball joint on the upper driver side it still sounds horrible. I have been told mabye the brake line is colapsing, and that could be making the poping sound i am hearing. Anyone know anything about that being a possibility??
Old Jul 21, 2008 | 12:45 PM
wink2873's Avatar
wink2873
how about tie rod ends and the steering rack? it may not be brake related, and i doubt the steel brake lines are collapsing.
Old Jul 24, 2008 | 10:19 PM
fireguy_64's Avatar
fireguy_64
ok new upper and lower ball joint on driverside, new brake pads on driver side.. And i still have the pulling to the left and poping sound?? My next guess i am thinking about is the driverside caliper?? Would that be the way to go or no?? Anybody with any grand ideas???
Old Jul 24, 2008 | 11:12 PM
f0x672's Avatar
f0x672
im 90% sure it's suspension related if the popping sound occurs when you hit bumps and such
Old Jul 26, 2008 | 10:36 PM
fireguy_64's Avatar
fireguy_64
OK after replacing both upper and lower balljoints on the driverside and it didnt fix it we looked harder. Had someone that hadnt heard what it was doing get in my truck and they heard the poping sound. Why he was in it he started tapping the brakes. The caliper was moving about 4" back and forth. We kept looking and finally found were the bar with the bushings on the upper A-arm was moving. We replaced the bushings and havent had any problems since we replaced them. Hopefully that took care of the problem.
