P0305 Mis-Fire after it rains
Old Jul 21, 2008 | 06:00 PM
MaxBaldwin's Avatar
MaxBaldwin
Default P0305 Mis-Fire after it rains
Hello,
I have a 02 Dakota with a 6 cylinder. It sits out in my driveway and after it rains my Cylinder mis-fires. This is with out driving it and just sitting over night.
Any Thoughts?
Old Jul 21, 2008 | 06:19 PM
moe7404's Avatar
moe7404
Default RE: P0305 Mis-Fire after it rains
moe in wichita ks
what is happening is the vent on the dist cap is letting moisture into the cap. the fix: take the cap off. fill the vent with j-b weld. use wd-40 or starting fulid to drive the moisture out. also check that the windshield washer hose has a hole in it. been there done that bought the tee shirt
Old Jul 21, 2008 | 06:23 PM
f0x672's Avatar
f0x672
bad wires, cracked coil and a bad seal in the distributor allowing moisture into it, do a tune up, spark plugs, cap, wires, and rotor, check the coil pack for a cracked casing
