QC Rear Seat Locked?
Old Aug 10, 2008 | 07:10 PM
yz125dakota's Avatar
yz125dakota
Default QC Rear Seat Locked?
i was messin around yesterday and my rear seat wont flip all the way up anymore it'll go as high as the small side the the big part of the seat that used to fold all the way will come up appx. 4-5" is there some sort of lock on these things? thanks
Old Aug 14, 2008 | 11:07 PM
mnl001's Avatar
mnl001
I had the same problem. I removed the seat and greased the the assembly with white spray grease, worked great after that for about a year. The seat is starting to act up once in a while again. Would like to hear if there is a perminent fix.
Old Aug 18, 2008 | 01:49 AM
tazzmenn's Avatar
tazzmenn
I had that problem too. I looked under the seat and found one of the kids running shoes under the seat keeping it from folding properly.
Old Aug 18, 2008 | 10:43 AM
f0x672's Avatar
f0x672
most likely it's seizing up from constant use, if you're feeling adventurous enough, pull it apart and use some lithium white grease, they will keep it lubricated no problem, the stuff looks like peanut butter.
