DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Dakota Tech (https://dodgeforum.com/forum/2nd-gen-dakota-tech-67/)
-   -   SAS dana 60's all around (https://dodgeforum.com/forum/2nd-gen-dakota-tech/171713-sas-dana-60s-all-around.html)
varsis Aug 13, 2008 04:02 PM
http://varsisstudio.com/axle/0812082016-small.jpg
http://varsisstudio.com/axle/0812082016a-small.jpg
First pics of the axles.
Now I need to figure out a few things, rebuild kit which one? And gears.
Not sure on tire size yet, either 38's or 42's im thinking
Gears 5.13 or 5.38 But which brand is what I want to know and same for the rebuild kit.
One other thing I would like to know is how hard is it to replace drum brakes or to put in disk brakes instead. Currently my truck is the same setup as the axles front disk, rear drum.
The front disk brakes look like an okay condition but would it be better to just replace them or to get them redone.
RoaminGnome Aug 13, 2008 07:38 PM
Id just check that the calipers work and at least get the rotors machined. Probably a good idea to get new pads too. I seriously want to do this to my dak so keep us posted. If it can be done for relatively cheap I may start saving my pennies :)
Just out of curiosity what did the axles come from and did you know the condition before buying them? Are they still good or do they need a ton of work to be at 100%?
varsis Aug 13, 2008 07:47 PM
The axles look good the rear needs brakes. the Front and rear both work Turn by hand. No major scuffs to the axles, locking hubs in the front. 1800 for both axles, the front is the expensive one, and really hard to find around here, front was a 79 with f350 and rear was from a 250. I didn't want a d70.
I just want to check everything out. Thats what I need.
RoaminGnome Aug 14, 2008 11:29 AM
Nice! Make sure to take lots of pics :)
If I ever attempt this Ill need all the help I can get.
varsis Aug 18, 2008 06:22 PM
Haven't posted on this in awhile but funds seem to be limiting for this. Going to cost a lot but it's going to be killer. So no worries. Lots of parts to order.
Here are some of them:
5.38 Reverse Thick Gear (Front)
Wheel Bearings
Dana 60 Rebuild Kits
5.38 Regular Gear.(REAR)
Disk Brakes For Rear.
Hydraulic Steering Parts
Coil Overs - Fox Triple Rate w/Shocks
Stabilizer Bar
8 - Johnny Joints
4 Link Bar with thick tubing
1 inch wheel spacers Maybe?
Brackets for Links.(Scrap metal?)
Rims and Tires.
Not sure what else but I think thats most of it.
batman13 Aug 18, 2008 06:33 PM
i can find you a heavy duty 4 link kit with brackets if your interested
batman13 Aug 18, 2008 06:34 PM
and i can find viper disc conversion kits
varsis Aug 18, 2008 06:36 PM
hmm if you can find it with 3 inch johnny joints and I can set the angles my self all I would want is the 4 link bars. Just one less thing for me to do. looking at 50 in lowers, and 40 in uppers. But might be better to do myself. I am doing triangulated.
batman13 Aug 18, 2008 06:43 PM
im also doing a triangulated 4link... odd how the same truck needs similar parts to go either up or down...lol
if you mount the bars to the inside of the frame you will need to move your gas tank
give kris dye fabrications a call
http://www.krisdyefabrication.com/main.sc
he'll make anything you want and hes good on prices
(let him know who sent ya hes a buddy of mine)
varsis Aug 18, 2008 06:47 PM
I sent u a PM Batman. But I am doing a front suspension not a rear suspension. The rear is leafs and staying leafs. Saves me time and money...
© 2026 MH Sub I, LLC dba Internet Brands
