ball joint replacement
Old Jan 31, 2005 | 01:37 AM
DakotaRT2K's Avatar
DakotaRT2K
Default ball joint replacement
I am wondering, since I've read here that oem replaced ball joints typically fail again. will Dodge replace with aftermarket ball joints, if I pay the difference. thanks ahead of time!
Ethan
Old Jan 31, 2005 | 05:19 PM
02dakota's Avatar
02dakota
Default RE: ball joint replacement
Probably not. The ball joints they replace with are revised and if installed properly, shouldn't fail(prematurly). However they will continue the warranty on them if they should fail. Later...
