Engine Caming at Idle
Old Sep 2, 2008 | 08:35 PM
zanethan's Avatar
zanethan
Default Engine Caming at Idle
My 1998 Dakota with the 3.9L cams at idle the engine speed varies by 100 RPMs at idle. What could be causing this.
Old Sep 3, 2008 | 10:47 AM
OneBadKota's Avatar
OneBadKota
Clean the IAC, on the back of the Throttle Body. I just did this to a '98 3.9l. Man was it dirty.
If it's not dirty, it will need to be replaced. It won't fix it right away, drive it for a bit, shut it off and go again. It will thin out.
It's held on by two torx bits, T-25s.
Hope this helps.
Old Sep 3, 2008 | 01:58 PM
zanethan's Avatar
zanethan
I already cleaned and replaced the IAC and it didnt fixed the problem. Could it be the cam shaft position sensor?
Old Sep 3, 2008 | 03:24 PM
OneBadKota's Avatar
OneBadKota
It's possible. In the cases I've seen when they've gone bad, the truck wouldn't run.
Could always replace it and see, if it don't work just return it.
Old Sep 3, 2008 | 08:05 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
i don't know a whole lot about the 3.9 but when my 4.7 started doing that it turned out being the TPS, i replaced that and everything was good
Old Sep 3, 2008 | 09:19 PM
TheePlaymaker's Avatar
TheePlaymaker
i hate the idle on these trucks i like my idle to just sit there when its idling like my old cherokee did mine is all over the place but usually around 600...maybe cleaning the tb would help a little but the tps sounds like a reasonable choice too my would idle bad and surge at speed went it went bad
