truck dies out while driving
Old Sep 3, 2008 | 11:29 AM
tony407's Avatar
tony407
New Member
Default truck dies out while driving
i have a 99 dakota v8 5.2L sometimes when i am driving the truck it will die out on me while i am driving. i then have to wait for about usually 10 15 minutes then it will start right back up like there is nothing wrong does anyone know what can be causing this.
Old Sep 3, 2008 | 11:33 AM
OneBadKota's Avatar
OneBadKota
Almost sounds like vapor lock, or the fuel pump is pooping out on you. I would hook up a gauge and see what PSI you're getting.
Old Sep 3, 2008 | 12:09 PM
varsis's Avatar
varsis
i had a coil do this to me... Drive fine, out of nowhere die... Sometimes would start sometimes not...
Old Sep 3, 2008 | 10:36 PM
ironcowboy's Avatar
ironcowboy
Sounds like just what i had, next time it dies, wiggle those wire grounds on the right side of the truck, and see if you hear the relays clicking in the box on the right side. If so its a bad ground. Thats what did it for me.
Old Sep 4, 2008 | 06:43 PM
tony407's Avatar
tony407
New Member
hey guys thanks for all the help here a little more info that might help me find the problem it only does it while i am driving it never does it first thing in the morning or whenever i go to leave somewhere its crazy. it always starts when first leave then thats when all the fun starts. like today it die out three times in the matter of like 5 hours. thanks again.
Old Sep 4, 2008 | 06:55 PM
varsis's Avatar
varsis
sounds like coil... mine would just random... But just check it all.
Old Sep 6, 2008 | 01:40 AM
tony407's Avatar
tony407
New Member
how do i check to see if its the coil do i just replace it and hope for the best or what. thanks for the help
