Squeaky problems
Old Sep 3, 2008 | 09:26 PM
mpbigham's Avatar
mpbigham
New Member
Default Squeaky problems
My truck, 99 dakota sport, squeaks while it is in drive and moving forward. The squeak is consistent with vehicle speed, and it stops when i put the truck in neutral while moving.
any clues?
Old Sep 3, 2008 | 09:50 PM
f0x672's Avatar
f0x672
we need your engine, transmission, and if it's a 2 wheel drive or 4x4 info. sounds like you got an automatic that's taking a dump, should be more of a high pitched whine versus a squeak
Old Sep 3, 2008 | 10:20 PM
mpbigham's Avatar
mpbigham
New Member
3.9, auto, 4x4
Old Sep 3, 2008 | 10:22 PM
mpbigham's Avatar
mpbigham
New Member
its a definate squeak and it does it only a low speeds under 25 or so
Old Sep 4, 2008 | 01:49 AM
varsis's Avatar
varsis
could be a bent in transmission/torque converter cover.
Also check your belts. Sometimes the load on the engine causes a Squeak. Can you maybe record the noise.
Chris
Old Sep 4, 2008 | 11:18 PM
mpbigham's Avatar
mpbigham
New Member
my cross member is bent, where the torsion bars go. i was hung up on a stump when i first bought the truck.
but it only squeaks when the truck is in drive?
Old Sep 6, 2008 | 08:34 PM
mpbigham's Avatar
mpbigham
New Member
the squeak is coming from the passenger rear tire. its more like a squeak... thunk?
