lift
Old Sep 21, 2008 | 11:36 AM
liljoe's Avatar
liljoe
Default lift
i have an 03 dakota and if i put blocks on my rear can i turn my torsion bars to the same level as the rear what should i go with 1 1/2 or 2"
Old Sep 21, 2008 | 01:09 PM
f0x672's Avatar
f0x672
you crank the t bars now the full 2 inches they can go without running into some critical issues, truck will be level, 0º rake
Old Sep 21, 2008 | 06:50 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Do yourself a favor though. Go to a junk yard, or to ford, and buy the 2" lift blocks that come on 4x4 rangers (all 4x4 rangers are 2" taller then the 4x2s in the rear simply from lift blocks).
These blocks are unbreakable, and no aftermarket aluminum or cast iron block will compare. Plus, the blocks are 2" which would be perfect for you, if your cranking the t-bars 2".
Good Luck!
Old Sep 21, 2008 | 08:55 PM
liljoe's Avatar
liljoe
thanks so ill go with 2" blocks and the turn my tosion bars untill the truck is level with out going over 8 turns right and that should make the it level.
it is a 4x4 is that still ok
