Butt plug in rear differential?
Old Nov 5, 2008 | 10:38 PM
dazeofmylife's Avatar
dazeofmylife
Default Butt plug in rear differential?
Hey guys...and girls...
I was shocked to see this rubber butt plug...in the differential where a large metal bolt should be. Should I weld a large nut onto the outside of the differential plate and put in a "real" bolt...the rubber plug was leaking slightly messing up the outside of the differential. Does the differential build up pressure that requires the rubber plug? Would I screw up by welding a large nut over the existing hole and using a nut instead?
Am I a nut?
Old Nov 5, 2008 | 10:40 PM
f0x672's Avatar
f0x672
the diffs have breather tubes on em, and its common for the rubber plugs to bleed a bit, but they do a decent job, so i wouldnt worry about it
Old Nov 5, 2008 | 10:56 PM
dazeofmylife
Geez, I'll hate to have to wipe the differential periodically to keep it clean.
If I were to soak it in brake cleaner would it seal better? If the breather tube..I think it's on top...was stopped up, would the rubber plug leak more? I don't have a clue what a rear end would cost...but I'll bet it upwards of $500...just want to protect my new...it's new to me...truck! And "if" the plug ever came out during operation, would it sling out all of the gear lube thus destroying the rear end?
Thanks FOx
Old Nov 5, 2008 | 10:59 PM
f0x672's Avatar
f0x672
yeah, a plugged breather will blow out a seal or in our case, will just cause more oil to pass by the plug. they dont come off with ease. it shouldnt be bathing the differential either from the plug.
Old Nov 5, 2008 | 11:16 PM
TheePlaymaker's Avatar
TheePlaymaker
yeah its 700ish for a new rear got my rebuilt in March because the stock LSD's in these are horrible but now I have a aftermarket one and i'm super happy.
Old Nov 5, 2008 | 11:45 PM
dazeofmylife
I love those dual exhausts on your truck Playmaker...think I might have to copy you!
What's the difference between a 8.25 rear end which is what I have and a 9.25 which is what you have...more torgue or something?
Old Nov 6, 2008 | 12:13 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
I was shocked to see this rubber butt plug...in my differential
with one littlest tweik...that makes a funny *** quote
Old Nov 6, 2008 | 08:46 AM
TheePlaymaker
its just a little bigger and more heavy duty. and thanks for the complements go right ahead. i loved the 15 degree rolled tip flush with the rear bumper look on the rams and thats what i tried to copy.
Old Nov 6, 2008 | 11:40 AM
4x4kota's Avatar
4x4kota
Are you trying to tell us that you have a rubber butt plug in your rear end?
Old Nov 6, 2008 | 11:44 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you never know with loudpedal i mean if you ask him to try something he will just FYI
