How to turn off child protection door locks
Old Nov 10, 2008 | 05:41 PM
CJ_Dakota's Avatar
CJ_Dakota
Default How to turn off child protection door locks
I have a 1999 Dodge Dakota 4X4 V8 and I want to turn off child protection door locks. It looks around 15 MPH. How do I turn this option off?
Thanks
CJ
Old Nov 10, 2008 | 07:32 PM
MadisonDakota's Avatar
MadisonDakota
I know on my 04. You cycle the key on and off ( i don't remember how many times) end with it on and then lock the doors. You should hear a conformation chime. I'll have to get my owners manual out.
Old Nov 10, 2008 | 08:42 PM
TheePlaymaker's Avatar
TheePlaymaker
unlock your doors after 15 mph haha jk not sure hopefully madison can find out for you
Old Nov 10, 2008 | 09:01 PM
batman13's Avatar
batman13
manual locks FTW....
Old Nov 10, 2008 | 10:21 PM
f0x672's Avatar
f0x672
+2, hahaha. i would think it's something the dealership can do with their scanners only. but if a keydance works also, sweet.
Old Nov 10, 2008 | 10:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea i think i read about a keydance for it too but i dont have my manual to check for ya so hopefully madison can get it
Old Nov 11, 2008 | 12:17 AM
MadisonDakota
Enter vehicle and close all doors.
Buckle up, seriously, it keeps the beeping down so you can tell which beep is right.
Place key in ignition.
Withink 10 seconds turn the key from on to off four times ending in the off positions.
Then "lock" the doors, with the power lock.
I take Paypal. *looks around*
jkjk
Old Nov 11, 2008 | 08:21 AM
TheePlaymaker
are there any other little nifty key dances other than this one and the one to get check engine codes.
Old Nov 11, 2008 | 10:05 AM
CJ_Dakota's Avatar
CJ_Dakota
Madison,
Thank you very much. I will try it this afternoon. Again, Thanks.
I will let you know how it works.
CJ
TheePlaymaker,
Thanks for the laugh, I needed that this morning.
Old Nov 11, 2008 | 01:58 PM
MadisonDakota
To check your engine codes:
Turn the key to ON (not start), OFF, ON, OFF, ON and leave it there. If you look in the odometer window the codes will flash any code(s) with a small delay between each result. Each code should be in a P#### format, and will say PDONE when completed - turn your key to OFF and remove. Use the OBD code list to determine what problem the computer detected.
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery
