Front bearings question. 2k dakota.
Old Nov 25, 2008 | 06:20 PM
syllinx's Avatar
syllinx
Default Front bearings question. 2k dakota.
I am going to do them once i get all the parts but I am wondering what size nut goes on the spindle. I went to autozone and they didn't have any sockets that would fit. I have the 2wd 3.9. Sorry for all the stupid questions. If theres anybody that I could email instead of spamming the boards lol that would be nice.
Old Nov 25, 2008 | 07:19 PM
varsis's Avatar
varsis
I believe it's a 32 mm. I had to take it off and I used the largest socket I have from what I recall, but just try it out on the nut. Take your hub off.
Old Nov 25, 2008 | 08:20 PM
syllinx's Avatar
syllinx
Default One more question lol.
Nobody has been able to help me so far on the seal question lol, do you have to buy wheel bearing seals for it also? Even though it's a sealed unit?
Old Nov 25, 2008 | 08:26 PM
varsis's Avatar
varsis
no. sealed is sealed... lol. when I did mine it was remove the tire, disk brakes, than the 3 bolts on the rear side and the middle nut, which i think is 32 mm...
Old Nov 25, 2008 | 08:28 PM
syllinx's Avatar
syllinx
Default Thanks.
Just worried.. if i got over 70 i swear the bearings scream at me but under 70 it's fine, no vibration. Just had balance done on tires also. I have to do it myself and the only thing I will really be worried about is i don't know how to torque the bolts since I can't afford a torque wrench. I was told to turn till it stops with hand then do one whole turn and it should be fine. Also i just saw part of the repair manual, it says to put grease on the spindle. Do you recommend any synthetic grease for the spindle?
