tires rubbing
Old Dec 2, 2008 | 12:31 PM
mskiel's Avatar
mskiel
Default tires rubbing
i have an 01 dodge dakota which i just purchased and it has 20" rims on it and when i turn they rub. i was wondering what are some cheap ways to lift the front or other ways to eliminate this problem without having to lift the entire truck. thanks alot
Old Dec 2, 2008 | 01:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is this truck a 4x4 or a 4x2? it makes a difference in what options you have, i
if you have a 4x4 you could crank the torsion bars to gain 1.5-2 inches (i think, havnt done it tho so im not sure)
if you have a 2wd then youw ill need to get spacers or lift springs
and more information on the truck is better
Old Dec 2, 2008 | 06:55 PM
mskiel's Avatar
mskiel
its a 2wd. and where could i get the spacers or lift rings?
Old Dec 2, 2008 | 07:41 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
also what kind of tires do u run? like what size????
i have 275 40 r 20 and theres no rub
Old Dec 2, 2008 | 07:45 PM
batman13's Avatar
batman13
yea, unless you have 32''+ tires they shouldnt rub
unleeesss.... the rims have a high offset that would cause your problem and wheel spacers could fix it or new rims
Old Dec 2, 2008 | 08:13 PM
varsis's Avatar
varsis
spacers is the way to go...
Old Dec 2, 2008 | 08:16 PM
RoaminGnome's Avatar
RoaminGnome
I dont think new rims is quite the cheap answer he was looking for lol
Yes if your wheel size is under 32" Id check the offset and get the right size spacers.
