V8 to V6 throttlebody
Old Dec 9, 2008 | 02:52 PM
KHS_Filipino7290's Avatar
KHS_Filipino7290
Default V8 to V6 throttlebody
Hey guys i'm new to the forum and I was looking into doing this mod... just trying to get my facts straight. So the 5.2/5.9 V8 throttle body is a direct bolt on to the 3.9 V6 only difference is the throttle linkage? as fas as the sensors go I can pretty much transfer the V6s to V8s correct? another question is there any noticeable difference between the two throttlebodies to distinguish them? Because I purchased my truck used and i'm not sure what has been modified on it other than the exhaust and removal of stock intake shroud only to be replaced by an edlebrock intake cover
Old Dec 9, 2008 | 04:26 PM
01SilverCC's Avatar
01SilverCC
Both TB's are about the same size. On the OE ones they will have V8 or V6 stamped in front of the bore. The bores are larger on the V8 TB. The linkage and sensors are the same for V6 and V8 TB's. You would use the sensors off the existing V6 TB because you know they work. You need to get the throttle cable from the dealer for the V8 TB for the same year or get the cable from the donor vehicle if you are using a TB from the junk yard. You have to do that to get the cable to match the linkage on the V8 TB.
Jimmy
Old Dec 9, 2008 | 04:59 PM
f0x672's Avatar
f0x672
^ yeah, please dude next time just search this. there was a TB conversion thread a week ago. btw welcome
Old Dec 9, 2008 | 07:01 PM
RoaminGnome's Avatar
RoaminGnome
Actually there were 2
And welcome to the site!
Old Dec 9, 2008 | 08:20 PM
KHS_Filipino7290
Ohh haha yea i'll do a search next time... Sorry new to the whole forum thing. This helped me so much thank you very much!!
Old Dec 10, 2008 | 12:32 PM
KHS_Filipino7290
ohh another question is there a way to modify the v6 throttle cable to accomodate the v8 linkage? or is there really no way around replacing the cable with the V8 cable...
Old Dec 10, 2008 | 01:01 PM
f0x672's Avatar
f0x672
youre better off replacing the cable
Old Dec 23, 2008 | 05:35 PM
KHS_Filipino7290
i actually got the v8 throttle cable... did anyone have problems with the length of the new v8 cable it seems that the one i have doesn't open the butterfly all the way when you push the pedal to the floor is that ok or do i need to cut the length a little ?
Old Dec 23, 2008 | 05:55 PM
f0x672's Avatar
f0x672
theres a rubber stop on the TB, so the butterfly valve doesnt perfectly open straight up.
