air bag light/ switch
Old Dec 19, 2008 | 11:54 PM
lamchop's Avatar
lamchop
Default air bag light/ switch
did anybody have problems with their pass. side air bag switch. everything started when i change my factory radio. i forgot to plug back in the air bag switch when i change the radio and i started the truck. well you all know what happen next, the air bag light went on. i didn't get a chance to get it clear till a month later. when they scan it, it read something like a bad ground or grounded wire. we try to clear it but it wouldn't let us do it because the problem was still there. they told me that they thick the air bag switch is bad that is why it is causing a ground. when we turn it on or off the light does not come on the switch. but they are not 100% sure. i was wondering you guys would know if i did something wrong when i change the radio? the radio works. is this really a switch that went bad when i touched it. i haven't gone out to check to see how much this piece will cost but i think it will be allot since i have to go to the dealer. i just don't have money to throw around if this is not the problem. thanks and sorry this was so long
Old Dec 19, 2008 | 11:59 PM
f0x672's Avatar
f0x672
did you plug it back in? could of yanked something lose if you were pulling on the wires
Old Dec 20, 2008 | 12:08 AM
lamchop's Avatar
lamchop
i plugged it back in when i first saw the light on the dash but it didn't go off. he looked at the plug to make sure everything looked good.
Old Dec 20, 2008 | 12:13 AM
f0x672's Avatar
f0x672
yeah, could possibly be though you yanked a wire loose somewhere in the harness during the install.
Old Dec 20, 2008 | 12:15 AM
lamchop's Avatar
lamchop
everything looked good on the jack, what i can see the wires look ok also.
Old Dec 21, 2008 | 02:11 PM
JC9995's Avatar
JC9995
Now that youve fixed the issue that caused the light to trigger, you will most likely have to have the SRS system reset at the dealer.
Old Dec 21, 2008 | 02:27 PM
lamchop's Avatar
lamchop
my friend has the scanner to reset it. the problem is the code is still there. it would not clear because the problem did not get fix. would the bulb being blown cause a ground fault? he said that we have to start at what we know is bad which is the switch.
