Dakota cranks but wont start?
Old Jan 22, 2009 | 07:25 PM
rtdakota2001's Avatar
rtdakota2001
good point, what are your plugs gapped to?
Old Jan 22, 2009 | 09:30 PM
beefjerky's Avatar
beefjerky
Heh, no idea. I've only had the truck for about a week. :P
I had a knowledgeable friend look at the truck today. He said it's pretty obvious the cat needs to be replaced, so we're going to start there.
Old Jan 22, 2009 | 10:43 PM
batman13's Avatar
batman13
pbbbt....
change the sensors on your throttle body, all 3
IAC, MAP, and the TPS, guarantee you it'll start and run 25.3 times better
in order clockwise, from my thumb,
IAC,(idle air controller,)
TPS, (throttle position sensor)
MAP, (mass air pressure)
do the MAP, then IAC, then TPS
then go from there
it wont be cheap, but you will replace them all soon enough
Old Jan 22, 2009 | 11:55 PM
rtdakota2001
i thought MAP stood for Manifold Absolute Pressure....
