water pump squeal?
Old Jan 29, 2009 | 10:31 AM
purpledakotart's Avatar
purpledakotart
Default water pump squeal?
Hello my dakota squeals from the point I start it till I turn the engine off, and gets louder with increase of rpms. I've replaced the belt, belt tensioner, idler puley, a/c clutch bearing and cleaned all puleys. So its either the water pump for fan clutch that has a bad bearing i'm thinking. Any help would be helpful.
Old Feb 2, 2009 | 10:17 PM
2daks's Avatar
2daks
Carefully crawl under the truck while it's running. You should be able to tell if its louder at the water pump from below. Check for seeping coolant in the weep hole on the bottom if your pump has one. With everything you've done seems like the water pump is likely.
Old Feb 3, 2009 | 10:03 AM
matj1990's Avatar
matj1990
well i just replaced myn and shes doing the same thing just not consistenly wich make me think myn is the fan ? but im not sure
Old Jun 25, 2009 | 05:32 PM
mgilorma's Avatar
mgilorma
did you ever figure out what was making the noise?
Old Jun 27, 2009 | 11:20 AM
purpledakotart
yeah it was the water pump, the bearing went out and the water pump wasn't but maybe two years old so these dakota must have isuses with the water pump bearing going out.
Old Jun 27, 2009 | 01:37 PM
rtdakota2001's Avatar
rtdakota2001
never heard that one before. mine is on 110k+ miles and there haven't been any persistent water pump complaints here on the forum...
Old Jun 27, 2009 | 04:03 PM
varsis's Avatar
varsis
waterpump bearings usually go because of lack of coolant.
