Spark plug heat shields. PITA
Old Feb 18, 2009 | 01:28 PM
jascoesens's Avatar
jascoesens
Default Spark plug heat shields. PITA
Hey all.
Just acquired a 98 Dak V6, 3.9L. Getting lousy gas mileage, so replaced O2 sensor. That got me up to 13.6 mpg. NEXT: went to replace plugs, wires, distrib cap & rotor. mpg pending.
Found the "Heat Shields" to be a royal PITA. Especially the one next to the vacuum booster (left rearmost).
Any suggestions how to remove the shields? Are they necessary?
Thanks.
James
Old Feb 18, 2009 | 01:29 PM
f0x672's Avatar
f0x672
remove them, they are useless. i removed mine, plug boots havent melted, so its good.soak em in pb blaster. get some vise grips, crimp the shield together, and get angry at it.
Old Feb 18, 2009 | 06:20 PM
RoaminGnome's Avatar
RoaminGnome
lol I can get angry, its kinda what I do
So they are just set in there? Are they that annoying?
Old Feb 18, 2009 | 06:45 PM
f0x672's Avatar
f0x672
yeah theyre pressed in, they make it a pita to remove the spark plugs, without those shield i was able to shave off about 15 mins doing a spark plug job
Old Feb 18, 2009 | 06:57 PM
RoaminGnome
well Ill keep that in mind when I do my plugs
Will the PB blaster effect anything. Do you spray the sleeves with the old plugs in? I like to ask the stupid questions, can you tell
Old Feb 18, 2009 | 07:01 PM
f0x672's Avatar
f0x672
you can as long as youre gonna replace the wires, otherwise remove them, but label what cylinder they go to
varsis's Avatar
varsis
ya keep the plugs in until you those shields off. Otherwise you will get debris in the cylinder.
