dakota issue
Old Mar 1, 2009 | 10:24 PM
bgibb68's Avatar
bgibb68
well the maf is at the throttle body....where are common vac leaks at...unless it's leaking under the tb??
Old Mar 1, 2009 | 10:46 PM
wink2873's Avatar
wink2873
I guarantee you its a vacuum leak. You probably forgot to put a bypass nipple back on or something. Either that or theres something wrong with your TPS.
Old Mar 1, 2009 | 10:47 PM
magnethead's Avatar
magnethead
depending on motor, theres 1-3 vacuum ports to the passenger side of the intake, rihgt below TB
Old Mar 1, 2009 | 11:18 PM
bgibb68's Avatar
bgibb68
well i guess i'll attack with some carb cleaner tomorrow and check for leaks and clean some connections....oh i gotta show ya the pics of the injectors...it's awsome
Old Mar 2, 2009 | 02:23 PM
bgibb68's Avatar
bgibb68
well i got some elec cleaner and cleaned the connectors for the tbs, maf, and iat and that fixed the idle problem. but now no oil pressure.
so now i get to drop the oil pan the screen and the pump....YAY
