oil pump
Old Mar 11, 2009 | 10:58 PM
jar1zx's Avatar
jar1zx
Default oil pump
Hi every 1 this is my 1st day here
i just got a 2000 4.7 4 door dakota. my 3rd dakota
i bought this truck off a lady i was doing a tree job for. she told me it had started making engine sounds and she did shut it off right when she heard it
i started it up 3 times oil gauge takes a few secs to build up runs, runs and sounds great for 2 mins then oil gauge drops to 0 and lifters start pinging and i shut it off, and it has engine sludge
i have it at the dodge shop right now getting a new oil pump put in
My Q is? am i wasting my money on oil pump? should i have went with a long block? and how do i get the oil build up flushed out?
2nd Q will the bumper recever off my old 94 dakota fit on the 2000?
ty for any help
Old Mar 13, 2009 | 01:41 AM
jar1zx's Avatar
jar1zx
guess no one in here had any luck in just replacing oil pump and saving engine?
i should find out in a few more days if it works on my truck if not does any one know of any good place's to get a long block?
2000 4.7 v8
o and i just found out today that the owner before me used the wrong kind of engine oil
Old Mar 13, 2009 | 01:54 AM
magnethead's Avatar
magnethead
2000 4.7 v8
I don't know that there is a "wrong" motor oil, unless they dumped like ATF or gear oil or somethign in it.....
It may have been losing oil pressure because the sludge was blocking off the oil filter and/or pump. How thick of oil is in it? 10W-30 or straight 30 should be fine....
Old Mar 13, 2009 | 02:03 AM
jar1zx's Avatar
jar1zx
was told at dodge today. 5-30 non detergent is suposed 2 be used. had 10 40 penn in it
Old Mar 13, 2009 | 02:23 AM
User's Avatar
User
I use 10w30 syn,
the sludge can be broken down in each oil change if you run some sea foam in the oil for about 10min before you change it.. do it every time you change the oil 3-5k miles and it should slowly get clean again.
not sure if the 94 will fit on the 2000, since 96-97 was the crossover to the new gen.
i would toss in some high milelage syn oil 10/30 and keep it tuned up.
New oil pump might have been a good idea, or the oil just needed to be changed or "topped off"
Old Mar 13, 2009 | 05:43 AM
dane25's Avatar
dane25
Welcome bro....
Old Mar 13, 2009 | 08:55 AM
f0x672's Avatar
f0x672
+2 on what user did. next time as a rule of thumb, always start with the filter. i beleive the 4.7s use 5w-30. correct me if im wrong. i know the 3.9/5.2/5.9 magnum engines used 10w-30
Old Mar 18, 2009 | 01:20 AM
jar1zx's Avatar
jar1zx
well thx for the help. Tomorow im suposed to get the truck out of the shop i hope it goes well
Old Mar 23, 2009 | 11:46 PM
jar1zx's Avatar
jar1zx
Default Update
I got mad at dodge shop. they broke to much crap
now im doing the work my self
to take off oil pan. i learned u must raise engine and take 2 nuts off tranny and raise tranmissoin up to. the take off oil pan,gasket,and tube with screen. clean out screen. i have done this so many times today im sick of it. but last time the oil guage has not dropped yet with 30 mins of running. i ran desiel 2 times thro it. and blew some of the bluild up out of bottom end, with an airhose. hope tomorrow goes better. i bought the truck like this but when i get it running u can bet ur *** i will keep the oil changed lmao
Old Mar 24, 2009 | 01:20 AM
User's Avatar
User
what did they brake?
