2004 Misfire
Old Mar 12, 2009 | 11:39 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
Default 2004 Misfire
So heres my problem. Three days ago i was driving my truck on some pretty flooded roads, and now my truck is running on 5 cylinders. What do you guys think could be the problem?
Thanks for any advice in advance.
Old Mar 13, 2009 | 01:29 AM
magnethead's Avatar
magnethead
figure out which hole is out first....the old fashioned plug-unplug method should still work on these motors?
Old Mar 13, 2009 | 04:20 AM
wink2873's Avatar
wink2873
you probably fried a coil pack or an injector wire. try figuring out which cyl is misfiring by using process of elimination with unplugging injector wires. once you find it, pull the spark plug. if it's wet and has gas on it that means its getting fuel but no spark. in that case i'd say its a coil pack. if it doesnt have fuel on it, then its probably an injector problem.
Old Mar 13, 2009 | 08:51 AM
f0x672's Avatar
f0x672
no codes i assume?
Old Mar 13, 2009 | 10:17 AM
tamcnally's Avatar
tamcnally
oh no there is deffinetly codes. its a solid code when it stops doing it, but then when it starts missing again it is flashing just like a misfire code. so, im kinda at a loss right now to figure it out.
Old Mar 13, 2009 | 10:42 AM
tamcnally's Avatar
tamcnally
i just went to advance so they could plug into it and it says it is a cylinder 5 misfire.
Old Mar 13, 2009 | 11:07 AM
magnethead's Avatar
magnethead
like wink and I said, pull the plug and see what it looks like.
