no throttle
Old Mar 16, 2009 | 11:22 PM
jj2329's Avatar
jj2329
Default no throttle
2002 dakota 4.7
truck will idle but when you give it gas it will either stall and die or no change in rpms at all, even at wot.
replaced tps, map, cps, cms.
Old Mar 17, 2009 | 02:08 AM
wink2873's Avatar
wink2873
check for codes? you can usually go to like advance auto or any chain like that and alot of them run the codes for free.
Old Mar 17, 2009 | 11:44 AM
jj2329's Avatar
jj2329
The truck has no throttle response, it won't go anywhere.Gonna try some more with it today.Getting a fuel pressure gauge.Maybe its the fuel,cause I can spray ether in it and it will idle up some.
