Computer problem?! help
Old Mar 19, 2009 | 07:39 AM
z250rider's Avatar
z250rider
Angry Computer problem?! help
Ok guys so i took my truck to a shop and they put a code scanner on the comp and it came up code 72 something about rom and ram read only checksum does this mean the comp is bad or i still need to change my sensor in the rear end i dont want to have to put a new comp in this truck if i really dont need to i know alot more about imports then dakota's haha
Old Mar 19, 2009 | 11:00 AM
rtdakota2001's Avatar
rtdakota2001
well there's your problem right there. haha.
Old Mar 19, 2009 | 03:00 PM
Altair's Avatar
Altair
Dak attack!
Do you have the specific wording of the code by any chance? When read with a scanner the code should be 'Pxxxx' where the x's are numbers, if you can get that code it may help determine where the problem is. I skimmed through the code list and didn't find anything referencing checksum but typically a bad checksum on an area of memory indicates a problem with that memory.
Old Mar 20, 2009 | 01:29 AM
big.bryant's Avatar
big.bryant
do the key trick, should be in a sticky at the top and that should give you the Pxxxx code, which you can find in another sticky at the top of the forum which will tell you your problem... hopefully this helps, let us know if you ahve any other problems
cheers.
Old Mar 20, 2009 | 07:01 AM
z250rider's Avatar
z250rider
i tried the key trick and couldnt get it to work lol but here are the 2 codes that i saw Code 71 is "RAM Read/Write" and 72 is "ROM Checksum im really hoping its jus the rear sensor
Old Mar 20, 2009 | 03:47 PM
wink2873's Avatar
wink2873
im calling b.s. on those codes. those are not real trouble codes. if you dont have a check engine light on, and the truck is running ok, you dont have anything to worry about. your truck is a 99 so the key trick should work... i think. if i knew how to put videos onto the computer i would go out and take a vid of an example and put it on youtube.... maybe someone else that knows how to do that stuff could do it?
Old Mar 20, 2009 | 03:58 PM
varsis's Avatar
varsis
cycle 3 times from the power on to the start position but don't start. On the last one just leave it forward.
Old Mar 21, 2009 | 12:43 AM
dodgerules86's Avatar
dodgerules86
Yea, get a real code, as said above, it will be like PXXXX. (Where "X" is a number)
AutoZone, or most any other car parts store, can scan for codes, for free.
Old Mar 26, 2009 | 12:12 PM
fishbait's Avatar
fishbait
When I get the codes I turn the key to the on position, so the gauge lights come on(not all the way to start), off, on, off, then on and leave it on. The codes then come up on odometer followed by a "pdone" after the codes have been displayed.
