transfer case advise plz
Old Mar 20, 2009 | 02:50 AM
pronovost's Avatar
pronovost
Default transfer case advise plz
hey the transfer case in my 1997 dodge dakota is toast and im having trobles finding one at the junk yards i am wondering do i need to look for just 97 t cases or could i put one in from a difernt year truck and would a durango t case work ps i have a 1997 3.9L auto truck thanks in advance for the help
Old Mar 20, 2009 | 02:55 AM
TheePlaymaker's Avatar
TheePlaymaker
others should bolt up as long as its the same transfer case...im a little tired right now and would look for it but i think there is a thread on here about which tcase certain trucks have...if its a 2wd 4wd hi n 4wd low setup on your shifter i think its a np 242 which is in jeeps as well these should work but im not 100 percent sure on that im sure others will chime in and ill check into it more for you tomorrow there are lots of good sites out there tho you'd be amazed at what a simple google search will do
Old Mar 20, 2009 | 06:10 PM
big.bryant's Avatar
big.bryant
just do a comprehensive search of google and this forum and you should get your answer... or you could go and talk to a dealer or transmission shop, they should be able to help you further...
Cheers and welcome to the forum.
Old Mar 20, 2009 | 07:50 PM
bpark8824's Avatar
bpark8824
I think its the Np231 they didn't put the 242 in the dakota
Old Mar 20, 2009 | 09:36 PM
varsis's Avatar
varsis
you can put different cases on, but you may need to change the output shaft.
Old Mar 21, 2009 | 06:24 PM
Kevioll's Avatar
Kevioll
When I bought my 94, it had a bad transfer case. I found I could get a jeep one for about $100 at the junkyard, where the Dakota one was $400. I believe I had to open the case and swap the rear output shaft, then reassemble. Np231
Old Mar 25, 2009 | 03:27 AM
pronovost's Avatar
pronovost
thanks for the help guys im goin to look in to the jeep t case swap
