how to tell bad P/S from lower joint?
Old Apr 3, 2009 | 02:55 AM
magnethead's Avatar
magnethead
Default how to tell bad P/S from lower joint?
latently, my truck has had the sporadic steering tight/loose/tight/loose thing going on. Today going to TMS, it was fine on the highway, but when i got in the track, I couldn't even turn the wheel. I had to do a U turn 3 times (it's amazing howlost you can get when signs aren't posted), and i probably went from reverse to forrward 2 or 3 times each U turn simply because i could not get the wheel to turn far enough. But yet, other times it was perfectly fine, like when i actually went and parked.
I'm thinking this is more like a P/S pump/steering rack issue? Because it's not consistent in timing or rotations of the wheel. Seriously, I only got like 1/2 to MAYBE a full turn either way then i just ran out of muscle.
Old Apr 3, 2009 | 03:37 AM
CSCustomCars's Avatar
CSCustomCars
Is the wheel still turning? Or is it binding? Is the wheel turning but very hard to turn? if so, most likely cause is the P/S pump. If it's binding, like getting stuck and you have to wiggle it to get it un-stuck, then it's most likely a mechanical issue like the ball joint as you said.
Old Apr 3, 2009 | 10:54 PM
magnethead's Avatar
magnethead
oh i could turn it, but it took a grizzly bear to make it turn. then it'd be fine. Then it's be stiff, then fine again.
was fine all day today.
Old Apr 4, 2009 | 12:14 AM
CSCustomCars
Yeah, it's probably a weak P/S Pump. If you have a jack, jack up your lower control arm (with the wheels chocked!) so that the tire is off the ground, but the control arms are still holding the weight of the truck. Then grab the top and the bottom of your tire and try to wiggle it. If it moves at all, then you have a ball joint issue. If not, it's the P/S Pump problem.
Old Apr 4, 2009 | 02:14 AM
magnethead's Avatar
magnethead
what i say lower joint, i'm meaning the u joint on the steering column that likes to sieze and then fall apart. not the balljoint..mines only 4x2.
Old Apr 4, 2009 | 03:10 PM
CSCustomCars
Oh sorry, misunderstood. But the same principle applies. The u-joint in the steer shaft would cause it to bind.
Old Apr 4, 2009 | 03:15 PM
BlackDak37's Avatar
BlackDak37
That discription that you gave is how my power steering rack acted before it went out. Does that year have rack and pinion steering?
Old Apr 4, 2009 | 10:58 PM
magnethead's Avatar
magnethead
indeed.
not the answer I wanted either. I'll just run it out till something fails long as it dont fail when i'm in a hurry to get somewhere!
