Main wiring harness adapter or new wiring harness?
Old Apr 8, 2009 | 04:26 PM
SgtFulton's Avatar
SgtFulton
Default Main wiring harness adapter or new wiring harness?
I have a 2001 Dakota 4.7, I swapped engine and tranny out of
2003 Durango into my Dakota. I have tried and tried to get it running
without any success. My problem could be, I'm using my Dakota computer, however the harness are a little different, 3 and 4 plugs.
Does anyone know if they make and adapter for these harnesses anywhere?
I might also need to know , where to get another complete harness for the 03' Durango 4.7 that I'm now trying to use. So where is a good place to buy for a good price??
Any other ideas will be appreciated.
Thanks
Old Apr 8, 2009 | 06:56 PM
big.bryant's Avatar
big.bryant
Sarge, i would check with your local pull and go or check on ebay/craigslist for a harness like that... btw did you swap a 4.7 from the rango? if you didn't that would explain the issue of the harnesses linking up.
Cheers.
Old Apr 8, 2009 | 10:51 PM
SgtFulton's Avatar
SgtFulton
Yeah, I put the Durango 4.7 in my Dakota. Using my Dakota computer. Not sure if this is going to work for sure or not. When I use the comp. to check my codes, I'm only getting IAT error. Other than that, it tries to start and won't. Sounds like its turning over and loading on fuel but won't fire up.
