Evap leak.
Old Apr 23, 2009 | 06:58 PM
2002Dakota4.7L's Avatar
2002Dakota4.7L
Default Evap leak.
I have had an evap leak for about a year now. I checked the evap vacuum hoses and only noticed a small bad spot in the end that attaches to the evap vac. pump. I cut that part out and put it back together. The light is still on.
When the light first came on I tried changing the fuel cap but that did not do anything.
My next question is that I noticed that the rubber connector that connects PCV valve to the PCV hose is also cracked. I went to Autozone and they can't get the PCV valve. I am looking to see if this could be possibly linked to my evap leak as the vacuum and evap system seem to be linked according to the underhood decal as well as the service manual? Or am I going to have to drop the fuel tank and check the hoses there. The evap canister hoses seem to be good.
Old Apr 23, 2009 | 07:39 PM
magnethead's Avatar
magnethead
I've got the same code, so...idk I havent even got under there to look.
Old Apr 23, 2009 | 08:24 PM
dodgeramguy85's Avatar
dodgeramguy85
I got the same thing right now too
Old Apr 23, 2009 | 10:59 PM
jar1zx's Avatar
jar1zx
same here 2
i smoked the evap system. no leaks.
other problem i have is truck wont rpm over 4grand. dash show's it should start 2 red line at 5 in a half full red line 6 grand 4.7 v8
any of yall have this problem?
Old Apr 24, 2009 | 02:21 AM
RockGuardedDak's Avatar
RockGuardedDak
Originally Posted by jar1zx
same here 2
plant it right to the floor, that will make her rev higher
Old Apr 26, 2009 | 08:23 PM
SeaWeedCT's Avatar
SeaWeedCT
Same code as well, my check engine light is always on unless I disconnect the battery and clear it. Tried fuel caps, smoking the system, pcv valve, nothing works. Have no clue on this one
