Dexron instead of ATF+4
Old Apr 27, 2009 | 03:09 PM
bpark8824's Avatar
bpark8824
$189 wow. When I got it done last year when I owned a 3.9 auto it cost $100.
I don't know I figure just flush it and have it fresh and done and you won't have to worry about it for a long time.
Old Apr 27, 2009 | 04:41 PM
Excoelis's Avatar
Excoelis
Thats $189 Canadian though. I was thinking about flushing it but from what I've heard flushing can be worse for the tranny than putting dexron in it!
Old Apr 27, 2009 | 07:11 PM
f0x672's Avatar
f0x672
only if its a high milage tranny that has never been serviced before.. i have mine flushed every 20K - 25K miles. plus new filter and fluid of course
Old Apr 27, 2009 | 07:37 PM
batman13's Avatar
batman13
a flush is good for the trans, even the high mileage ones
it can be screwed up though which is why ppl say its worse
Old Apr 27, 2009 | 09:17 PM
rtdakota2001's Avatar
rtdakota2001
batty is correct, done properly, it shouldn't have adverse effects.
Old Apr 30, 2009 | 02:09 PM
TheePlaymaker's Avatar
TheePlaymaker
find a place that does the flush where they hook it up to a tub of clean fluid and then just let the tranny pump in the new and out the old untill its clean its the best way to do it there is a place by my house that does it that way i'm not sure exactly what its called though and your tranny is at least a little better and more reliable than the ones behind the 3.9, 5.2 and 5.9
Old May 1, 2009 | 03:47 PM
rpowell's Avatar
rpowell
I agree with all the advice you have been given. Also make sure if your truck has a spin on return filter that they change that one as well. These tranny's are made to shift soft (by slipping into gear instead of hard shifting like normal tranny's), so I am putting a TransGo shift kit in mine. Seriously stick with the stuff Mopar calls for it is expensive, but if these things are taken care of and changed at regular intervals they are pretty bullet proof. The fluid is kinda like the oil in a motorcycle with a wet-clutch, you can't just use any 'ol type because it will mess with the friction plates. My tranny mechanic said if done right he barely ever see's one go out (these tranny's are also used in some RV's, at least that's what he said). I have 152000 on mine and runs strong as ever.
Old May 1, 2009 | 05:29 PM
varsis's Avatar
varsis
you can flush it yourself pretty easy
put the truck in neutral pull the line off coming from the tranny, (by the rad.) You can run the tranny just about dry this way. just keep toping the tranny up to keep it from running dry, and you will know when it starts to get close to the end it slows down a bunch. run about 12-15 litres through the tranny
