Fan clutch nut
Old May 1, 2009 | 11:53 PM
Texvan's Avatar
Texvan
Default Fan clutch nut
I have a 2001 dakota with the 3.9L with ac. I have read all the posts here about removing the fan clutch nut, and 90% of the stuff ends up talking about electric fans and how much better they are. I need help on removing the 36mm nut on a mechanical fan, without this turning into a electrical fan discussion please. I rented the tool from autozone, but it is worthless being as the water pump pulley doesnt have bolts on it. I have tried seafoam ( I think thats what its called ) on it to loosen it up and tried the channel locks and hammer trick, and the tension on the belt does nothing, the pulley still moves. Any other advice out there that will help? Also the threads on here say turn it counter-clock wise being its a left thread nut, the hayes book says turn it counter clock wise being as it is a right thread nut, which is it and is it counter clock wise looking at it or the direction of the engine? Thank you in advance for any and all help!
Old May 2, 2009 | 12:04 AM
primus454's Avatar
primus454
For our Silverado, we had the get the water pump and fan off. Then we locked the water pump up in the vice and got the nut with a monkey wrench. I forget details, but thats how we did it.
Old May 2, 2009 | 12:10 AM
95_318SLT's Avatar
95_318SLT
When I pulled mine off, I stuck two bolts in the pulley (if it's like mine, there should be 4 holes). I know they won't thread in, but slide a bolt into 2 of the holes and put a long flat head screwdriver or small prybar in between them to hold the pulley still.
Old May 2, 2009 | 08:11 AM
Texvan's Avatar
Texvan
Thanks, gonna try and find some place to take it that has a anchored Vice I guess
Old May 2, 2009 | 12:50 PM
f0x672's Avatar
f0x672
use pb blaster to loosen the bolts.. not seafoam, this stuff goes into the engine to clean out the carbon build up
Old May 2, 2009 | 12:52 PM
varsis's Avatar
varsis
vice grips on the pulley and jam it up and take a hammer to the tool.
Old May 2, 2009 | 01:31 PM
Texvan's Avatar
Texvan
tried the vice grips thing, and a table vice, wouldnt budge. finally just took it to a mechanic and about 3 min worth of his impact wrench it finally gave in. Thanks for the help
Old May 2, 2009 | 03:33 PM
big.bryant's Avatar
big.bryant
notice a difference yet?
