Distributor Indexing???
Old May 6, 2009 | 11:40 PM
Jam1982's Avatar
Jam1982
Question Distributor Indexing???
Hey.
I have a 2003 Dakota 3.9L.
I want to verify the Indexing On my distributor but I am not sure of the procedure.
Does anyone know where I can find this info??
Old May 7, 2009 | 02:05 AM
User's Avatar
User
More info please, what do you mean by Index?
If your talking about TIMING then all you have to do is hook a obdII scanner, undo the lock down nut and slightly turn the distributor and get it as close to 0-1 as possible, but not in the "-" area.
Old May 7, 2009 | 04:38 PM
Jam1982's Avatar
Jam1982
By Indexing I mean Proper Posistioning.
also EFI Has No timing advancement unless you install MSD Ignition or similer.
the Distributor controls Fuel Syncronization To the ignition.
The Ignition Timing retard/advance is computer controled.
Old May 8, 2009 | 01:24 AM
User's Avatar
User
Yeah i think i referded to it as fuel timing adjustment, but anyways, on an OBDII Scanner i was able to adjust it.. on my truck was set at +4 and was able to bring it down to 0-1 ran better at this point...
here is a link to do what your asking, i found it on another forum..
http://www.dodgedakotas.com/boards/v8/11246.html
