5.9 throttle body and injectors
Old May 10, 2009 | 12:26 AM
stewartj1998's Avatar
stewartj1998
Default 5.9 throttle body and injectors
got an extra 5.9 throttle body and a set of 5.9 (red) injectors, would it be worth the time and effort to put these on my 5.2? any conflicts? any gains? what do ya'll think?
Old May 10, 2009 | 01:31 AM
usmrocks's Avatar
usmrocks
throw them on my 3.9
Old May 10, 2009 | 03:11 AM
wink2873's Avatar
wink2873
if you did it would be a complete waste of time, they're exactly the same as whats on your 5.2.
Old May 10, 2009 | 06:18 AM
User's Avatar
User
Yep what Wink said...
The 5.2 and 5.9 are the same motors, the 5.9 is just a over bore version of the 5.2. They use all the same boltons, injectors, and tb...
an upgrade for you would be a true 50mm Tb or 52mm TB, the stockers off the 5.2 and 5.9 are 50mm but are really 48mm.
stock inujectors should be 19 or 21lb injectors, a set of Ford Mustang PI injectors will be an upgrade for yours, 24-26lb, but if your close to stock upgrading injectors wont be much help at all. Upgrading injectors should only be done when your running to lean or are blown or using n2o.
You can sell that TB for about 30-50$ online or local, and if the injectors are good, im sure you can get some money from those also.
Old May 10, 2009 | 06:20 AM
User's Avatar
User
o and by the way... where you located in TX?
DFW Dakotas is having a Meet and Greet in Grapevine TX May 30th. You should come and bring those parts, im sure somone will buy them off you.
Old May 10, 2009 | 11:10 AM
magnethead's Avatar
magnethead
That's not in the form of a question. If us V6'ers show up, consider them sold. I plan to feed my 5.9 TB to the die-grinder after school ends and I go home.
Old May 10, 2009 | 11:39 AM
stewartj1998
thanks for the quick info guys, i won't be wasting my sunday off!!!!
Old May 10, 2009 | 11:48 AM
stewartj1998
i live in azle, supposed to go run my wifes gtp at dinasuar dyno day on the 30th (my ls1 truck buddy and i have a tuning business, lots of possible business there!) what time and where at, i would love to hang around some mopar heads for a change!!!!
Old May 10, 2009 | 01:57 PM
User's Avatar
User
Its in Grapevine, i live out in Justin behind the Texas Motor Speedway. Azle is about a 30min drive for me. I use to date a girl out in Azle.
here is the flyer i made for the meet. All the info you need is on it.
Old May 10, 2009 | 03:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if i was in texas i would be there, but im in NJ so no good for me
