2000 Dodge Dakota Sport idle problem
Old Jun 5, 2009 | 08:48 PM
red_dakota's Avatar
red_dakota
Default 2000 Dodge Dakota Sport idle problem
I just bought A 2000 Dodge Dakota Sport with 4.7 L V8 Magnum with 167.000km on it and i've notice that being in P wth engine on the idle goes up and down ( from 650RPM TO 750 OR 800 RPM ) so the idling is not stable,doesn't matter if engine is warm or cool.
i also notice small muffler leak ( the leak is located before the 1-st oxygen sensor, wondering what could cause the idle fluctuation ?
the previous owner changed the rims from 15' to 16' right now truck has 265x70rx16 on it,does affect the speedo or something else that i could worry about ?
thanks in advance, IRENE
Old Jun 5, 2009 | 10:25 PM
rpowell's Avatar
rpowell
Sounds like it may be your Throttle Position Sensor (TPS), but a dirty or failing Idle Air Control (AIC (just caught this I meant IAC, what a goober I am ) will affect idle also, if the exhaust leak damaged your O2 sensor it would mess with mileage not sure about idle and yes your speedo might be wrong. Do a search using the search link and you should find more precise answers to your questions. There is a site you can use to calculate the difference your speedo will, but I can't remember it so maybe somebody will chime in.
Hope this helped a little.
Old Jun 5, 2009 | 11:12 PM
wingerak92's Avatar
wingerak92
265/70R16 is a stock tire size.. well it is on my 02 sport. I just put some 265/75R16 on it so My speedo is out. But, the tire size wouldnt effect the idle.
Old Jun 5, 2009 | 11:28 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
Originally Posted by rpowell
(aic, i think that's what it is called)
iac**
