water leak.
Old Jun 7, 2009 | 12:16 PM
coreed's Avatar
coreed
Default water leak.
i got a 98 dakota with the four banger and there is water leaking from the bell housing. its not runing around the bell housing, only out the bottom. so could there be a freeze plug on the back of the block that you cant get to unless you pull the trans or engine?
Old Jun 7, 2009 | 02:57 PM
huseman808's Avatar
huseman808
i believe there are two of them on the back. And yes, the motor must be pulled to access them.
Old Jun 7, 2009 | 11:27 PM
ibcnul8r's Avatar
ibcnul8r
Are you sure it's not condensation from your A/C, from a drain tube??
Old Jun 8, 2009 | 04:05 PM
coreed's Avatar
coreed
i replaced all the freeze plugs in the motor except the ones on the back a week ago cause they were rusting through. lol. i need to pull the motor anyway cause i got to change the flywheel and it needs some new gaskets as well.
Old Jun 8, 2009 | 04:09 PM
coreed's Avatar
coreed
the a/c dont work. the condensor leaks and the compresor shaft seal went out.
