will this work?
Old Jun 26, 2009 | 11:56 PM
worldindistrie's Avatar
worldindistrie
Default will this work?
http://cgi.ebay.com/ebaymotors/Lift-...ht_2274wt_1191
will this work on a 03 dodge dakota sxt 2wd? ... also does this need to be professionaly installed
Old Jun 27, 2009 | 12:17 AM
DuckandDodge's Avatar
DuckandDodge
yes, today me and a buddy of mine put these on a 03 dak 2wd qc. you can buy the blocks for the rear blocks at autozone for $30.
its basically a body lift.
edit: and no it does not have to be professionally installed. although it would be best to do it with some friends that know a but about trucks.
Old Jun 29, 2009 | 06:23 PM
worldindistrie
how long did it take you to do?.. did u need anything else aside from the inserts
Old Jun 29, 2009 | 06:30 PM
bpark8824's Avatar
bpark8824
I would assume you need an allignment once you're done...
Old Jun 29, 2009 | 07:00 PM
JMNeel's Avatar
JMNeel
They will work BUT I would highly recommend using rubber spacers and NOT aluminum.
And as long as you have the tools and knowledge to pop a ball joint from the spindle and slowly lower a spring you should be able to do it. Note: it will be harder to get the spring back in with the spacer than it was to get out.
Oh and I bought the aluminum blocks from autozone for the rear of my truck, BIG MISTAKE! just a heads up.
Old Jun 30, 2009 | 01:16 AM
DuckandDodge
complete, about 5-6 hrs spread over 2 days to do. i suggest getting new front shocks from auto zone. do the front first because it may be level with just that and you will have the clearance for the same size bigger tires on both front and rear and yes you will need an alignment after.
Old Jun 30, 2009 | 04:20 AM
big.bryant's Avatar
big.bryant
pics?
