how long do rear drums last??
Old Jul 14, 2009 | 12:10 PM
kooshball's Avatar
kooshball
Default how long do rear drums last??
how many miles are you all getting from your rear drum brakes before having to replace them?
Old Jul 14, 2009 | 12:13 PM
f0x672's Avatar
f0x672
general rule of thumb, every 3 sets of front brakes you go through, replace the rears. however dont live by this guideline. check the thickness to make sure it's within spec or on riveted shoes, replace them once the rivets grind into the drum. the drum pratically has the same service length as a rotor. can be cut to a certain point where it needs to ve replaced. however a drum must be replaced if it shows abnormal wear or is damaged (cracks, out of round, etc)
Old Jul 15, 2009 | 02:29 AM
big.bryant's Avatar
big.bryant
they last quite a bit longer than the fronts (thats for damn sure!) but from what i have heard every else its once every 3 (like f0x said)
