Axle, Rear, Corporate 9?
Old Jul 14, 2009 | 04:47 PM
Czechman's Avatar
Czechman
Default Axle, Rear, Corporate 9?
On the glove box door there is a list of equipment in my truck. Included in that list is "Axle, Rear, Corporate 9"
What the heck is that?
Old Jul 14, 2009 | 07:13 PM
wink2873's Avatar
wink2873
should be 9.25... thats just what rear axle you have.
Old Jul 14, 2009 | 07:17 PM
Czechman's Avatar
Czechman
Well, what does it mean? Is it an option and if so how does it differ from the stock?
Old Jul 14, 2009 | 07:23 PM
wink2873's Avatar
wink2873
there are two rear axles that came behind dakotas. the first one is the 10-bolt 8.25 rear end and the second is the 12-bolt 9.25. The 9.25 axle is a little bigger and is supposed to be a little stronger, lots of v8's came with the 9.25, but not all of them. The 9.25 will handle more torque than the 8.25.... although its by no means a bullet proof rear end.
Old Jul 14, 2009 | 07:26 PM
wink2873's Avatar
wink2873
there have also been some v6's that came with the 9.25 from the factory. It appears that there is no definate pattern of which trucks came with which axles, except for the case of R/T's... which always came with the 9.25 rear because of the massive amount of torque the 5.9 puts out. However, most of the time 3.9's came with 8.25's, but some came with 9.25's and most v8's came with the 9.25, but some came with the 8.25.
Old Jul 14, 2009 | 07:48 PM
CSCustomCars's Avatar
CSCustomCars
I thought the 9.25's came as an option on all trucks but was included with the towing package and the 5.9 R/T's? That's what the dealer said.
And if I remember correctly, it's called a corporate 9 because Chrysler didn't make it. It's a supplied Axle, and Corporate is either the name of the company or the same of the supplier or something like that.
Old Jul 14, 2009 | 08:08 PM
bpark8824's Avatar
bpark8824
Yes it is a corporate axle, meaning Chrysler didn't make it. And like Wink said its a 9.25" rear axle, open differential. If it said LSD it is limted slip, if it does not say anything, its open.
Old Jul 14, 2009 | 08:25 PM
RoaminGnome's Avatar
RoaminGnome
So some 5.9s came with the 8.25?
Old Jul 14, 2009 | 10:32 PM
Czechman's Avatar
Czechman
Thanks guys, I appreciate the info. Mine is a LSD.
Old Jul 15, 2009 | 02:20 AM
big.bryant's Avatar
big.bryant
be careful tho, i have the 9.25 w/ LSD and I've already shattered my LSD clutch packs once now making just above stock power... these things aren't the best so if you are looking to make power, be sure to beef up the rear end.
Cheers.
