Brake issues
Old Jul 22, 2009 | 02:47 PM
raiders98's Avatar
raiders98
Default Brake issues
Today I had to stop pretty fast so I hit the brakes pretty hard and after that the brake pedal was really easy to push down and i had to push it all lthe way down for the brakes to work. The Brake and ABS light came on after that. I got up under the truck and about halfway down the truck on the passenger side there is a leak somewhere. Anyone got some ideas as to what happened? Maybe just needs a new hose?
Old Jul 22, 2009 | 02:58 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
you blew a brake line somewhere. and the light probably came on because there is a low level of fluid in the reservoir.
Old Jul 22, 2009 | 04:43 PM
deranged's Avatar
deranged
Better not drive it till you fix the line or you'll be in for more trouble.
