Transfer case!!
Old Aug 6, 2009 | 12:29 PM
dak2000ota's Avatar
dak2000ota
Default Transfer case!!
2000 dakota 4.7l 5speed manual i need a transfer case mines a 231 can i put a 242 in it? and does anyone have one?
Old Aug 7, 2009 | 02:08 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Not to sure but you should know a nv242 is a full time transfer case. Mostly from jeeps. No one wants this transfer case. The upgrade you should look for is the nv241. I'm not sure what it takes to swap one on. But do a search I'm sure it has been discussed already. Check all of the forum, Rams may have done it too.
Old Aug 8, 2009 | 02:25 AM
Independentfool's Avatar
Independentfool
the 231 is pretty strong, and can be built up even stronger. Are you lifted with 35's + ?
the 241 is optimal if you are a serious crawler. its 4:1 ratio is too low for the average weekend warrior.
