fan clutch threads
That is exactly what I did to mine. When I put on electronic fans.
There are several things you can try to remove the fan if you can't get it off. They sell a special tool to hold on to the water pump pulley. You can leave the belt on and use a wrench to tighten up the belt to help. some have used a air hammer to hit the side of the nut to spin it.
