Tire rotation squeak
Old Aug 24, 2009 | 04:43 PM
daksport99's Avatar
daksport99
Default Tire rotation squeak
Hi all - I'm having a problem, which seems to occur in relation to colder weather. I own a 99' 4x4 3.9 V6 Dakota and live in a place where the summers are 90+ degrees......my truck is fine in warm temps, but if it is chilly at night or in the morn, once my truck starts moving, with every wheel rotation, there is a very loud watery squeaky noise.....it isn't a grinding noise......as stated before, if it's really warm out, no noise.......once it cools of, the noise occurs........lasts for a few minutes then eventually goes away.....any ideas? Can't tell where it's coming from although it sounds like it is coming from the front.....thanks!
Old Aug 26, 2009 | 12:02 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Tons of possibilities. Try to figure out if it is the brakes or wheel bearings. Lift up on wheel at a time with a jack and check to see if you can find it.
