gears?
Old Sep 3, 2009 | 05:23 PM
Josh Abels's Avatar
Josh Abels
Default gears?
ok i no someone will tell me i shouldve used the search option, but my computer freaks out for some reason when i use it.
but i am thinking about putting new gears in my truck, its a 4.7 2wd, im lookin to get some better acceleration, but it is my daily driver
what would i be lookin at as far as price, and how hard are they to replace, and what should i get, im not sure about what rear end i have i think is a 9.25 but how would i double check this
Old Sep 3, 2009 | 05:28 PM
f0x672's Avatar
f0x672
http://www.ringpinion.com/
will help you out with all you need
Old Sep 3, 2009 | 05:41 PM
Josh Abels's Avatar
Josh Abels
well it looks like i do have the 9.25 diff
Old Sep 3, 2009 | 06:03 PM
magnethead's Avatar
magnethead
if 3.55, go 3.92. if 3.92, go 4.10. If you can afford the gas, 4.56.
Old Sep 4, 2009 | 11:49 AM
Josh Abels's Avatar
Josh Abels
http://www.ringpinion.com/ProductDet...px?ProdID=5660
so is that all i would need or would i have to buy other stuff
and how hard is it to change them out, i mean do you have to line them up exactly right or is just an assemble to the same way it looked before it was disassembled?
Josh Abels's Avatar
Josh Abels
and what is the difference between the one i just put in last post and this one:
http://www.ringpinion.com/ProductDet...px?ProdID=2475
Old Sep 4, 2009 | 12:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Don't know. Probably the strength of the material. Call them up and ask.
Old Sep 4, 2009 | 12:54 PM
Josh Abels's Avatar
Josh Abels
well ill prolly go with the more expensive ones because they look like they r name brand
and that is the only thing ill need to get correct?
Old Sep 4, 2009 | 01:16 PM
CSCustomCars's Avatar
CSCustomCars
It's not as simple as pulling them apart and putting them back to together. You have to check pinion depth, and back lash. You also have to pre-load the pinion gear.
If you don't know how to set all of these properly or have someone to help you, then I'd take it to a shop.
Old Sep 6, 2009 | 02:43 AM
rtdakota2001's Avatar
rtdakota2001
you wont hardly notice going from a 392 to a 410. if you have a 392 just bite the bullet and go big. but since your betching about acceleration, I'm gonna guess you have a 355.
