I have a 97 dakota extended cab 4x4. it had a 3.9 and i goit a 5.2 and trans from a 98 jeep grand cherokee. i went to drop it in and the starte is on the passengers side as where my 3.9 had it on the drivers. so when i went to drop in the motor the motor mount is in the way of the starter so i cant put the starter on. also the oil pan is sitting on the front axle. will this motor even work in my truck? i dont know what to do. do i need to get a different motor?
do the magnum motors (doh, that's where you went wrong...it's not a magnum motor?) not have starter locations on both sides like the older chevy blocks did?
