big problem 2000 dakota
Old Sep 21, 2009 | 09:04 PM
rnddwn's Avatar
rnddwn
Default big problem 2000 dakota
i got a 2000 dakota 4wd 4.7L after driving it for about 1 hour it gives me multible codes a trans code crank code idle speed code cam code the fuel pump just run nonstop oh and it dies i thought it was the ecm so it is new i got new battery had the alt checked it is fine so now im lost can anyone help
Old Sep 22, 2009 | 07:55 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Dakota section,
FF
Old Sep 22, 2009 | 09:23 PM
rnddwn's Avatar
rnddwn
ok i have tested the charging system found a bad ground strap so it is fixed but the thing is still not right the fuel pump sometimes dont shut off it just runs and still getting a cam code so i put a cps on and still pops up and idle speed controll so for a run down i put cps on ecm and fuel purg and i keep getting closer but still broke and running out of money
Old Sep 23, 2009 | 10:39 PM
rnddwn's Avatar
rnddwn
if i get a po340 code could that make the fuel pump run funny like not cycling or just not stop running untill you turn the key off
Old Sep 24, 2009 | 02:25 PM
sigraph's Avatar
sigraph
Did you have the ecm flashed at a dealership with your vin # program?
If you bought an aftermarked computer, that could be the problem.
Old Sep 24, 2009 | 07:27 PM
rnddwn's Avatar
rnddwn
it was doing the same thing before i changed the ecm
Old Sep 26, 2009 | 08:26 PM
rnddwn's Avatar
rnddwn
found the problem the crank sensor was failing with heat
