2008 intake manifold
Old Sep 25, 2009 | 02:55 AM
donkshow's Avatar
donkshow
Default 2008 intake manifold
Will an intake manifold off of a 2008 4.7HO fit a 2000 4.7? or will it take additional mounting hardware?
Thanks
Old Sep 25, 2009 | 12:33 PM
TheePlaymaker's Avatar
TheePlaymaker
it takes some additional hardware and is worth it to go with a 70mm throttle body when you do it too i was just looking into this the other day and everyone said it gives you a pretty good boost...bad thing is its like $550-600 i was looking on airram.com's site and he has a thing so you can connect the throttle body to the 08 manifold and some other things to mount the throttle cables and what not since the new ones are cableless
Old Sep 25, 2009 | 07:40 PM
wingerak92's Avatar
wingerak92
I hear it jsut does more power at the higher end of the RPM range. but it also keeps the lower grunt as well
Old Sep 26, 2009 | 06:06 AM
donkshow's Avatar
donkshow
ok, so has anyone done a swap in the past or know what it takes to make it fit?
